Activity Forums Adobe After Effects How do I update a psd. brought in as a composition?
  • How do I update a psd. brought in as a composition?
    Posted by Joshua Chaulk on July 3, 2014 at 1:26 pm
    I’m doing some character animation in After effects CC and I brought my character psd file into after effects as a composition so i can animate the layers all separately. I just finished rigging up the character and I just realized I forgot to add some more details to the character. Is their a way I can update the composition to match the updated psd file?
    Joshua Chaulk replied 12 years, 2 months ago 4 Members · 4 Replies
  • John Cuevas
    July 3, 2014 at 1:44 pm
    Select the layer in the project window, press “cntl+e” to edit original, edit then re-save. Should automatically update in AE.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Brian Charles
    July 3, 2014 at 1:47 pm
    From After Effects Help:
    Refresh footage items
    To refresh footage items selected in the Project panel to use the current versions of the source footage files, choose File > Reload Footage.
  • Joseph W. bourke
    July 3, 2014 at 1:50 pm
    Select the layer you need to update in your time line, hit CTRL+E and it will open the graphic in Photoshop. Make your changes, then save it and return to After Effects and it will be automatically updated for you.
    Be careful not to add layers or rename layers, or it could mess up your AE composition. If you add layers, you will need to re-import the layers as a composition, then copy and paste to where you need them. Here’s a good discussion of some of the issues with layered PSDs:
    https://forums.adobe.com/message/2538678
    Joe Bourke
    Owner/Creative Director
    Bourke Media
    http://www.bourkemedia.com
  • Joshua Chaulk
    July 3, 2014 at 2:52 pm
    Thank you the ctrl + e worked wonderfully.
