Activity › Forums › Adobe After Effects › How do I update 1 composition that is used across multiple projects?
  • How do I update 1 composition that is used across multiple projects?
    Posted by Bill Clay on August 4, 2016 at 6:25 pm
    I have 10 separate AE projects.
    They all use the same 5 second composition at the beginning.
    Is there a way to update the 5 second composition without opening each AE project?
    Looking back, I think I should have built everything into 1 project file, instead of 10.
    Bill Clay replied 10 years, 1 month ago 2 Members · 3 Replies
  • Bill Clay
    August 4, 2016 at 8:10 pm
    Thank you, sir.
  • Kevin Camp
    August 4, 2016 at 8:14 pm
    if the 5 second composition can be replaced by a clip, pre-render the 5 second comp in one of the projects, then replace the 5 second comps in the other projects with the render.
    pre-rendering has a post-render action that will automatically import the rendered clip and replace the pre-rendered comp with the clip. it won’t delete the comp, so you can make changes in the future and simply pre-render it again.
    or, you could import the other projects into single project, replace any shared comps with a single instance of the shared comp and then you’d have all your projects within a single project… make a change to that 5 second comp once, and it will be reflected in the others…
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Bill Clay
    August 4, 2016 at 8:21 pm
    much thanks, sir.
