Activity › Forums › Apple Final Cut Pro Legacy › How do I uninstall FCP HD completly???
  • How do I uninstall FCP HD completly???
    Posted by Per Lindh on April 14, 2005 at 2:06 pm
    HELP!!!
    I have several computors in a network and I did the BIG misstake to mix up my licenses and install the same program disc on to computors and when I reinstall the right disc on the right computor it uses the serial number from the disc I installed by misstake.
    I want to remove FCP HD and install the right programdisc with the right serial number. I have tried various way to throw everything with connection to FCP and the programs included (compressor, Soundtrack etc.), and when I try to instal the “right” program with the “right” serial number it ends up with the serial number as the program I installed by misstake. How do I get rid of the wrong serial number.
    Todd Reid replied 21 years, 5 months ago 3 Members · 2 Replies
  • Jeff Carpenter
    April 14, 2005 at 2:59 pm
    Search your hard drive for “Final Cut”
    You’ll probably turn up some folders in the two Library folders. Erase anything you find. You can dig through those folders yourself (One is on the System drive, the other is deeper in ‘Users’) but I think that a simple search should turn find them for you.
  • Todd Reid
    April 15, 2005 at 12:43 am
    https://docs.info.apple.com/article.html?artnum=93811
    I’ve uninstalled successfully following this apple sponsored document.
