Activity › Forums › Maxon Cinema 4D › How do I turn on physical camera settings in an existing camera
  • How do I turn on physical camera settings in an existing camera
    Posted by Craig Ricker on May 23, 2012 at 3:50 am
    Ok so the story goes:
    I have an exisiting project with 4 cameras in it. None of them have physcial camera properties like F-stop available. I have gone and turned on the physical renderer and made sure motion blur and depth of field were enabled in the settings.
    But….
    Still have no options to change f-stop and exposure etc in the camera’s physical properties.
    I have made a new project, set all those options to on and made a new camera and the options are available?
    Any ideas
    heres the project file
    4190_cameraissues.c4d.zip
    Craig Ricker replied 14 years, 4 months ago 2 Members · 4 Replies
  • Adam Trachtenberg
    May 23, 2012 at 2:22 pm
    The problem is that you don’t have the physical render preset active in render settings. It’s highlighted, so you can see the settings, but in order to make it active you have to click the icon to the left of the preset name (looks like the active camera icon).
  • Craig Ricker
    May 24, 2012 at 12:21 am
    Thanks for the reply, I do not see this icon? There is no buttons next to any of the words “physical” in the render settings. I’m using cinema 4d broadcast, and as far as i’m aware I should have access to the f stops etc and I DO, in a new project, just not in this existing project 🙁
  • Adam Trachtenberg
    May 24, 2012 at 3:40 am
  • Craig Ricker
    May 24, 2012 at 4:00 am
    You beauty! Thankyou
