Activity › Forums › Apple Final Cut Pro Legacy › How do I turn 16:9 to 4:3 the right way?
  • How do I turn 16:9 to 4:3 the right way?
    Posted by Ross Marshall on March 27, 2006 at 9:18 am
    This may seem like a stupid question but I’m really not sure I am doing the right thing. All my footage I capture is full 16:9 DVCPro50; however I need some of this footage in 4:3, what is the best way to convert this in Final Cut. Surely if I scale my 16:9 footage on a sequence 4:3 this just enlarges the pixels, meaning I will lose resolution?
    Please Help
    Martin Baker replied 20 years, 6 months ago 8 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    March 27, 2006 at 1:51 pm
    Ross,
    [Ross Marshall] “Surely if I scale my 16:9 footage on a sequence 4:3 this just enlarges the pixels, meaning I will lose resolution?”
    Nope!!! Converting 4×3 to 16×9 enlarges the pixels, going in the other direction involves either cropping or panning and scanning a selected portion of the image. Try your dropping your nested into a 4×3 timneline and see what happens.
    DRW
  • Mark Maness
    March 27, 2006 at 3:11 pm
    No… it doesn’t enlarge anything. Just use the Distort tab on the Motion tab in your viewer window. Change the Aspect to 0 and adjust your left and right side to 320 and -320 (I think that is the numbers…). At least that will get you in the ballpark, then adjust from there.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Matt Sandström
    March 27, 2006 at 3:47 pm
    you got two replies that i frankly don’t understand. workflow-wise they are right but of course any kind of cropping and stretching enlarges the pixels and yes, unfortunately you’ll always lose some resolution. it’s not that bad though so just live with it.
    /matt
    https://www.mattias.nu/
  • Captain Mench
    March 27, 2006 at 5:01 pm
    Check this out and see if it doesn’t answer a few of your questions:
    https://www.proapptips.com/proapptipsvideotutorials/879F6B61-CFF9-4FD1-8D43-FDF89605611A/6ECEC931-47F1-4BC1-8CD4-41FE4842B45D.html
    CaptM
    ps – if that link didn’t work, go to https://www.proapptips.com/captmench and choose the MultiAspectRatio one.
  • Nick Righton
    March 27, 2006 at 5:02 pm
    Hi There. I have had to convert my 19:9 HDV footage to 4:3 regularly. I create a new sequence in the project. Select the new sequence. Type “command+0” and click on Load sequence. Select a 4:3 format of your choice and cut and paste the desired content into the new sequence. This works if you want or don’t moind a letterbox. I have had good reults with this technique.
  • David Roth weiss
    March 27, 2006 at 6:04 pm
    [Matt] “cropping and stretching enlarges the pixels”
    Stretching yes, cropping no.
  • Matt Sandström
    March 27, 2006 at 6:06 pm
    it’s and, not or. obviously.
    /matt
  • David Roth weiss
    March 27, 2006 at 6:07 pm
    Nice tutorial Captain.
  • Michael Alberts
    March 28, 2006 at 1:16 am
    If you want a full frame 4:3 center punch go with the method suggested by Wayne. There is no loss of quality using this method. We also use a hardware aspect ratio converter to do this, but the results look identical.
    Michael Alberts
    Ambidextrous Productions, Inc.
  • Matt Sandström
    March 28, 2006 at 7:49 am
    Hey kafka, this is more and more confusing. Since i know you guys aren’t stupid you just gonna have to explain better. How can you not lose any resolution if you crop out 30 percent of the image? 16:9 material contains exactly the same amount of pixels to begin with…
    /matt
