Activity Forums Adobe Premiere Pro How do I Synchronize time of nested sequences?
  • How do I Synchronize time of nested sequences?
    Posted by John Rowe on February 23, 2011 at 3:54 am
    When I use Nested Sequences and I double click on a daughter sequence inside my main sequence, while Premiere does open the daughter sequence the timeline cursor does not reflect the same position within it. This makes jumping between mother and daughter sequences while editing really confusing. Is there any way to fix this?
    In After Effects you can set a preference setting to do this called “Synchronize Time of All Related Items.”
    Is there any Premiere equivalent?
    Any help greatly appreciated,
    John
    John Ricca replied 12 years, 6 months ago 8 Members · 13 Replies
  • 13 Replies
  • Alex Udell
    February 23, 2011 at 2:14 pm
    So you want to open parked on to the corresponding match frame in the nest?
    I agree this would be handy….I don’t think there is a way to mod the behavior.
    Would make an excellent feature request.
    As a klunky work around….
    1) in main timeine, mark an IN at the head of the nested clip and an OUT where you want to park.
    2) note the duration
    3) Open the nest
    4) use the noted duration to know where you need to move the Time line cursor…or just “+” and the value of the duration and “enter” to jump to that point in time quickly
    Alex
  • John Rowe
    February 23, 2011 at 10:28 pm
    Thanks Alex.
    It’s a bummer Premiere can’t do this. Sometimes I wish Premiere was just a little bit more like After Effects.
    Then again, I wish After Effects could play video in realtime instantly like Premiere can. 😉
    Thanks again,
    John
  • Ann Bens
    February 23, 2011 at 11:12 pm
    Try Shift+T.
  • John Rowe
    February 24, 2011 at 12:49 am
    Thanks Ann,
    That’s a huge help! 🙂
    John
  • Alex Udell
    February 24, 2011 at 11:51 am
    Nice Ann…
    thanks!
    Alex
  • Ann Bens
    February 24, 2011 at 2:03 pm
    A while a go i was pointed out to this shortcut too. 😉
  • Errol Lazare
    April 21, 2013 at 7:42 pm
    Awesome!
    Was looking everywhere to do the same thing.
    Thanks for that.
    Errol X. Lazare
    EXL Films
    http://www.exlfilms.com
  • Nora Kuro
    July 4, 2013 at 9:05 am
    Does anyone know if there is any similar shortcut in PP CS6?
  • Errol Lazare
    July 5, 2013 at 4:07 am
    Shift+T should work in premiere pro CS6. Works for me.
    Check to see what your keyboard shortcuts are set to. Mine are set to Final Cut Pro keystroke.
    Errol X. Lazare
    EXL Films
  • Ben Slavens
    January 27, 2014 at 2:07 am
    I am trying this shortcut in PP CS6 but it is not working for me. I have the nested sequence selected, and pressing Ctrl+T does nothing..I tried Ctrl+Shift+T as well, no luck. What am I doing wrong here?
    Ben
