Activity › Forums › Adobe Premiere Pro › How do I switch back from using my external monitor as playback to a regular window with dialog boxes with files, I’m a FCP convert
Posted by Luke Christopher on July 24, 2013 at 11:28 amI think all you had to do was hit F12 with FCP, is there such a function in Premiere? It’s driving me crazy and I’m on a deadline. Thanks!
Andrew Johnstone replied 11 years, 4 months ago 4 Members · 5 Replies -
Peter Garaway
July 24, 2013 at 2:55 pmHi Luke,
If your working in Premiere Pro CC you can go to the Program monitor panel menu and deselect Enable Transmit (you can also assign a keyboard shortcut for this).
If your in Premiere Pro CS6, go to Preferences> Playback from there you uncheck your 2nd monitor. You can also go this route in CC.
Peter Garaway
Adobe
Premiere Pro -
Luke Christopher
July 24, 2013 at 3:25 pmI just have CS6 not CC so that option is not there, only to go to the playback preferences, which is a pain. Hmm, any other solutions?
Peter Garaway
July 24, 2013 at 3:47 pmAs I stated in my previous post. CS6 does not have a keyboard shortcut to disable transmit, however you CAN create a keyboard shortcut to open the Playback preferences. Do a search for playback in the keyboard shortcuts dialog.
That will be your fastest route to enable/disable transmit in CS6.
Peter Garaway
Adobe
Premiere Pro -
Andrew Johnstone
May 11, 2015 at 4:10 pmI have just run into this problem in CS6 as well.
All was fine until I did any update a couple of days ago to try to eliminate another issue I was having. to toggle the external monitor off, I normally go Preferences>Playback and toggle my external screen off. Except after this update, toggling the monitor off does not work. I have to Quit & restart Premiere.
Is there a solution? Perhaps some permissions issue?
Thanks for any help.
Andy Johnstone
Wild Dog Limited
film & multimedia production
http://www.wilddogworld.com
