Activity Forums Apple Final Cut Pro How do I split audio from video in Final Cut Pro X?
  • How do I split audio from video in Final Cut Pro X?
    Posted by Scott Allen on April 3, 2018 at 3:41 pm
    OK, maybe I should ask, “Is it possible for me to manually sync audio in Final Cut X – especially if the audio and video are already joined?”
    I’ve been using Final Cut 7 for the last several years. I work at a film archive, where we scan archival film. Much of this film was shot in the earliest sound era by Fox Movietone cameramen. Single-system sound, with 11 frame separation between the image and the corresponding sound. Obviously, before 22 or 24 frame separation became the norm.
    Whenever we scan a film that was shot this way, we have to pull the pic ahead by 11 frames. In Final Cut 7 this is very easy – just grab the picture track and pull it ahead. Or type in “11” and enter, and the track moves itself.
    Enter Final Cut X and this is an unnatural act, an impossible dream, Apple knows best, blah, blah, blah. 8^) . I’ve tried a number of different ways and have searched online for a solution with no luck so far. Does anyone here have a suggestion?
    Thank you in advance…
    Scott Allen
    Moving Image Research Collections
    Univerity of South Carolina
    Bret Williams replied 8 years, 5 months ago 5 Members · 5 Replies
  • Warren Eig
    April 3, 2018 at 4:57 pm
    Separate audio and video– detach. Sync and then make compound clip?
    Warren Eig
    O 310-470-0905
    email: info@babyboompictures.com
    website: https://www.BabyBoomPictures.com
    Vimeo: https://vimeo.com/babyboompictures
    For Camera Accessories – Monitors and Batteries
    website: https://www.EigRig.com
  • Jeff Kirkland
    April 3, 2018 at 6:28 pm
    As above – or in the clip browser, select the clip, choose ‘open in timeline’ and move the audio as required?
    Jeff Kirkland | Video Producer & Cinematographer
    Hobart, Tasmania | Twitter: @jeffkirkland
  • Scott Allen
    April 3, 2018 at 8:46 pm
    Great thanks to you both. I didn’t know how to “detach” at first, but once I tried “open clip in browser”, I was able to grab the sound and move it independently of the video. However, I could only move the audio forward – not move the video forward. So, I inserted a gap clip at the head, shortened it to the eleven seconds that I needed, and was then able to pull the audio back to the right spot.
    It works now, though I wish there were a slightly easier way – but this isn’t hard. Thank you both very much!
    Scott Allen
  • Gregor Queck
    April 3, 2018 at 9:39 pm
    “open clip in browser”:
    You can insert a gap at the beginning of the video clip (Alt-W?) and then move the sound ‘backwards’.
  • Bret Williams
    April 4, 2018 at 9:00 pm
    Wouldn’t it make more sense just to trim off the first 11 frames of the audio, then move it backward? You don’t need the 11 frames that don’t have visual most likely.
    _______________________________________________________________________
    https://BretFX.com FCPX Plugins & Templates for Editors & Motion Graphics Artists
    Hang Tag https://bretfx.com/product/hang-tag
    Overshoot Text https://bretfx.com/product/overshoot-text/
    Outliner https://bretfx.com/product/outliner/
    Clock Maker https://bretfx.com/product/bretfx-clock-maker/
