Activity Forums VEGAS Pro How Do I Slow Down A Pan/Zoom
  • How Do I Slow Down A Pan/Zoom
    Posted by Sully Sullivan on August 14, 2005 at 11:25 pm
    I started out a photo montage with a greeting card. It was long and vertical so I zoomed into the top part and panned down so you can read the words as the card pans from top to bottom.
    My problem is the pan starts at a good speed to read, then about a fourth way down it speeds up, then slows down again as it gets towards the bottom.
    How can I get it to maintain a nice slow and steady speed throughout the downward pan?
    Mike Sullivan
    Sully Sullivan replied 21 years, 1 month ago 2 Members · 2 Replies
  • Mike Kujbida
    August 14, 2005 at 11:54 pm
    In the menu on the left-hand side, set the Smoothness (under Keyframe Interpolation) to ‘0’. If you have more than one keyframe, you’ll have to do this for each one. For future reference, setting this to ‘0’ before you do anything will avoid this problem. It’ll also set all future keyframes in the event to ‘0’.
  • Sully Sullivan
    August 15, 2005 at 12:35 am
    Thanks for your help Mike!
