Activity Forums Adobe After Effects How do I simulate a camera flash?
  • How do I simulate a camera flash?
    Posted by Doug Horton on May 14, 2008 at 9:44 pm
    I filmed a subject on the green screen holding an old camera with one of those big flashes, and she pushes the button, but of course it doesn’t work anymore. So how do I simulate the flash going off? Lens Flair tool, but I cant get it to look realistic at all.
    David Bogie replied 18 years, 3 months ago 4 Members · 4 Replies
  • Joey Foreman
    May 14, 2008 at 11:55 pm
    Lens Flare simulates the effect of light reflected back onto a camera lens when the beams of a light source enter it directly. You know – a lens flare. You see it in movies all the time.
    Give CC Light Rays a try. You can position its point of origin, and I usually just apply it to a one or two frame adjustment layer. Tweak its defaults, give it a blue tint, etc.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Pat Jaeger
    May 15, 2008 at 6:24 am
    Ryan Wieber has a method of creating contact flashes when lightsabers collide which might work perfectly for a camera flash as well. Go to:
    https://www.ryan-w.com/ryan-w/tutorials_sabers2.html
    and follow the steps in the ‘contact flashes’ section
    Pat Jaeger
  • Doug Horton
    May 15, 2008 at 2:56 pm
    Ok great, thanks so much guys!!
  • David Bogie
    May 16, 2008 at 6:52 pm
    If you want realism, shoot it. The problem with faking flashbulbs is the light source is a point. This creates directional light that casts hard focused shadows. You cannot put that in as a post production overlay with any convincing degree of “realism”.
    needlessly pedantic:
    Old photo flashbulbs were filled with a coiled metal thread or foil. When energized with a small amount of current with the shutter, an ignitor squib started a chain reaction that not-quite-instantly caused the metal to combust. There is a slight ramp-up of the light output from the bulb that is imperceptible but the end of the physical sequence is quite noticeable. The glass bulb envelope reaches red or white hot temperatures and, as the metal plasma cools, the amount of light ramps down and the color of the light changes.
    bogiesan
