Activity Forums Apple Final Cut Pro Legacy How do I shift all markers in Final Cut Pro?
  • How do I shift all markers in Final Cut Pro?
    Posted by Matthew Davies on July 16, 2012 at 10:59 pm
    I have a whole bunch of DVDSP chapter markers all set up in an FCP sequence. However, I want to add a little 5 second splash screen at the beginning of the sequence. How do I shift all the chapter markers so that they aren’t all off when I add the splash screen?
    Matthew Davies replied 14 years, 2 months ago 2 Members · 5 Replies
  • Shane Ross
    July 16, 2012 at 11:04 pm
    Do an INSERT EDIT and they should move down. If you have them set to RIPPLE. And this only works if you have FCP 7.
    Shane
    Little Frog Post
  • Matthew Davies
    July 16, 2012 at 11:06 pm
    That would be it! Thanks so much!!! You saved me!!!!!!!!!! 🙂
  • Matthew Davies
    July 16, 2012 at 11:08 pm
    Now that I’ve solved that, I do have another question. How do I copy a section of video and the chapter markers associated with them?
  • Shane Ross
    July 16, 2012 at 11:09 pm
    You don’t. The markers are either on the clip, or on the sequence. They aren’t connected.
    Shane
    Little Frog Post
  • Matthew Davies
    That’s what I figured. Thanks anyway!
