Activity Forums VEGAS Pro How do I set it so that by default, it does not “maintain to fix aspect ratio”?
  • How do I set it so that by default, it does not “maintain to fix aspect ratio”?
    Posted by Tony Chen on August 31, 2017 at 3:45 am
    So every time I try to drag an image over a video (whose aspect ratio is not the same as video), it tends to crop out the edges. I have to manually drag the borders so that I can see the entire image on the screen. Is there a default setting for this?
    Here is the problem: https://i.imgur.com/PXOoufk.png
    View post on imgur.com
    Tony Chen replied 9 years ago 1 Member · 0 Replies
  • 0 Replies
