How do I set audio levels in vegas 11?
John Rofrano replied 13 years, 7 months ago 6 Members · 12 Replies
Grzegorz Kwiatkowski
February 3, 2013 at 10:37 pmJohn,
I think you forgot to mention about the VU meters. The reference VU should be around -3 and not exceed 0.
John Rofrano
February 6, 2013 at 3:37 am[Grzegorz Kwiatkowski] “I think you forgot to mention about the VU meters. The reference VU should be around -3 and not exceed 0.”
Actually no. If you gave a broadcaster audio at -3 dBFS they would probably reject it. Re-read my post. You need to conform to the specifications of the broadcaster. In my example above for PBS I use Wave Hammer as a brick wall limiter to ensure that the audio never goes above -10 dB. If you send PBS audio that is above -10dB you will get your show rejected. Using -3 dB for home video or creating music CD’s is fine but broadcast audio must conform to the specifications of the broadcaster which I have never seen that loud. You are correct that any audio should never go above 0 dBFS or you will experience hard digital clipping.
~jr
http://www.johnrofrano.com
http://www.vasst.com
