Activity › Forums › Adobe After Effects › how do i seperate X & Y on the opacity parameter?
  • Steve Bentley
    October 25, 2018 at 1:03 pm
    Would changing to a velocity graph help? You can do that here in the curve editor.
    I’m not sure I understand the reference to opacity – it only has one attribute but yes you can change the curve on that in the curve editor. Opacity is just a number between 0 and 100 so it doesn’t have an x or y. The position the point has on the curve is just the value mapped against where keyframe is in time.
  • Nitai Lev-oren
    October 25, 2018 at 1:08 pm
    The problem was I can’t do a U shape parabola that is symmetric or not, but you help me and I changed it to the
    value graph on the button you said and now I can.
  • John Heiser
    October 25, 2018 at 2:33 pm
    Change your keyframes from linear to Bezier, and the proper handles will appear in the graph.
    John Heiser
    Senior Editor
    o2 ideas
    Birmingham
