Activity › Forums › Adobe After Effects › how do i separate X & Y on the scale parameter?
Posted by Nitai Lev-oren on October 28, 2018 at 9:03 amhow do i separate X & Y on the scale parameter, because I can’t bend the keyframes?
Nitai Lev-oren replied 7 years, 10 months ago 2 Members · 7 Replies -
Mark Doctor
October 28, 2018 at 2:37 pmX,Y and Z, it only works on 3D-layers. So make it 3D first.
Greets Mark
Nitai Lev-oren
October 28, 2018 at 2:42 pm -
Mark Doctor
October 28, 2018 at 4:10 pmAh i see the problem, im not near an AE-workstation currently, but if a direct solution is needed:
Add 2 sliders from expression control to your layer and pick whip x to one and y to the other. After that you can add both slider value’s to your graph-editor.
Array’s in AE don’t have separate value’s in the graph editor. That’s the reason for the separated (position) dimensions.
Nitai Lev-oren
October 28, 2018 at 4:23 pmwhy there is this on the position and you can seperate the X and Y and the scale you can’t?
Mark Doctor
October 28, 2018 at 5:50 pmFor the true reason you should now why array’s are used. That’s a lot of computer science and in the end you probably agree the way it is ????
(Enemy of the state)
Fiedler: The satellite is 155 miles above the Earth. It can only look straight down.Jones: That’s a bit limited, isn’t it?
Van: Well, maybe you should design a better one.
Nitai Lev-oren
October 28, 2018 at 5:53 pmyea you probably right, thanks for the answer about the slider.
