Activity Forums Adobe After Effects How do I see vector handles?
  • Kevin Camp
    December 19, 2011 at 5:12 pm
    if you are seeing points and/or vector outlines, then the paths have been copy/pasted from illustrator onto a solid in after effects.
    importing an illustrator will only allow ae to ai vectors continuously rasterize (always remain sharp), but not actually edit the vectors themselves… (unless something has changed is version 5.5)
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • John Cuevas
    I downloaded the project files and it looks like he created the text in Illustrator, copied the paths, made a solid in AE and pasted the paths.
    You could also just use the text tool in AE, select the layer and under the layer pulldown choose “create masks from text”
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Darren Ruddock
    December 20, 2011 at 4:17 pm
    Thanks guys!!
