Activity Forums Apple Final Cut Pro How do I see keyframes?
  • How do I see keyframes?
    Posted by Olly Lawer on October 5, 2012 at 10:00 am
    I’ve set a few keyframes (scale). I want to be able to see these on the clip as I need to move them. Having great difficulty selecting the last frame of the clip! So want to just set it earlier and then move the keyframe to the end. I cannot see where on the timeline they show? They show on the audio, but not on the video.
    Olly Lawer
    Robert Wright replied 13 years, 2 months ago 3 Members · 2 Replies
  • Ian Bailey
    October 5, 2012 at 11:30 am
    Select the clip and use Ctrl-V to bring up the Video Animation panel. Click on Transform: All and you can select Scale from the menu.
    You can drag the keyframes left or right to change the timing and you can add more keyframes by Option-clicking. You can’t change the scale in the Video Animation panel, for that you’ll need to go to the Inspector or use the Transform controls in the Viewer.
  • Robert Wright
    July 11, 2013 at 9:11 pm
    Outstanding…Hit Ctrl-V and everything was right there. Thank you!
    Thanks…
    Rob
