Activity › Forums › Apple Final Cut Pro Legacy › How do I Run Video in Reverse
Posted by Springer on April 25, 2005 at 4:09 pmNewbie question….how do I set things up to run a shot in reverse? Thanks!
Mel Matsuoka replied 21 years, 5 months ago 3 Members · 3 Replies -
Jerry Hofmann
April 25, 2005 at 4:17 pmDouble click the shot from the Browser or from the timeline window, type cmd+j… then click on the reverse option.
Jerry
Apple Certified Trainer
Author: “Jerry Hofmann on Final Cut Pro 4” Click here
Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
Mel Matsuoka
April 25, 2005 at 8:50 pmKeep in mind, however, that Reversing a clip this way will degrade the quality of your video clip, since FCP does not properly reverse the field order.
The best solution to this if you want to uphold the best quality, is to use Graeme Nattress’ free “G Reverse” filter (https://www.nattress.com/free.htm).
btw, it was great to meet you “IRL” at the Apple training booth at NAB, Jerry!
Aloha,
mel
