Activity › Forums › Apple Final Cut Pro › How do I roll Video Only in FCP X
Posted by David Mcwhinney on February 4, 2013 at 4:25 amHi All
In FCP 7 if I want to roll only the video I hold down the option key
How do I do that in FCP X
If it is possible , does it work in both a primary storyline and connected clips?
ThanksDavid
Dan Boyd replied 12 years, 7 months ago 11 Members · 19 Replies -
Noah Kadner
February 4, 2013 at 5:15 amFirst expand Audio/Video (Control-S). Then you can trim audio and video independently.
Noah
Call Box Training.
Featuring the Panasonic GH2 and Panasonic AC160/130. -
David Mcwhinney
February 4, 2013 at 6:03 amThanks Noah
Worked as you say…shame you can’t hold down a key like FCP 7
Been using FCP since version2 , been checking out X to see if I can do a news edit on it
I am a veteran news editor ( BBC , CNN and now Aljazeera English)
We currently edit our news stories in the field with FCP 7 and FTP back to office.
Shoot on XDCAM at moment.
Trying to get a workflow for FCP X to do a news edit.
Still confused when to use a storyline and a connected clip
Basically will have a reporter track , a couple of interviews and a reporter stand up and wondering where best to place them……cant seem to roll video on connected clips
Anyway, many thanks for your help -
Bill Davis
February 4, 2013 at 8:31 amDavid,
X should be super easy and effective for what you’re trying to do.
A key is to learn to leverage the two stage edit design of X.
Import and work FIRST in the event browser. Do NOT go straight to the timeline as you are used to in FCP7.
To do so robs you of much of what’s efficient and special about X.
Pre organize and even Pre-edit in your event browser first. Use the temporary dashboard tags (Favorite or Rejected) to eliminate the dreck from field tapes and narrow your focus. Then skim and range select and tag just the story’s narrative thread using keywords. Do this to both the best of your standups and actualities and the best of your B-Roll. Apply keywords to ID them. Only then open a new storyline and Drop those assets into it and use the magnetism to arrange the flow. Essentially you do your clip ID and trimming work in stage one, and your story building in stage two. Lastly use the keywords and ranges you applied to your B-roll to add those shots as connected clips – creating classic cutaways.It might sound more complex then the classic process of building everything on a timeline in one operation, but you’ll soon start to see how the new process of Pre organizing, tagging ranges and applying keywords in advance frees you to blast through edits, alternate versions and changes with amazing speed and efficiency.
It’s a new way to think and work, but everyone I know who’s embraced it can’t imagine going back to single stage editing for short-form time sensitive work like a news story.
It’ll take some adaptation and learning on your part, but the X workflow, once learned, I suspect will transform your job and make it a lot easier.
FWIW.
Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
Neil Patience
February 4, 2013 at 4:13 pmHi David
I would be interested to know what you think of Bills suggestions about keywording, tagging and pre organising. He is totally correct about that being the best way to make X work and he knows X very well.
What I was wondering was if you feel you have time to do all that in some scenarios. My experience of being on the receiving end of news feeds cut in the field is that you have very little time, often minutes to just quickly top and tail a piece to camera, maybe add some B Roll and play out down the line.
I often work in quick turnaround sports news and we get feeds from correspondents where they literally trim a PTC from a presenter, leave gaps for B Roll that perhaps contain just V/O and play out. I then fill in the gaps with the appropriate B Roll, add a lower third or two, make sure everything is mixed and the file gets transferred to the studio for TX, often with minutes or even less to spare to air time.There is no reason why you couldn’t cut those pieces in the field with X, but do you feel you would usually have time to exploit its excellent database options ?
best wishes
Neil
http://www.patience.tv8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7 -
Steve Connor
February 4, 2013 at 4:17 pm[David McWhinney] “Still confused when to use a storyline and a connected clip
Anyway, many thanks for your help”While Bill’s answer is a very efficient use of all FCPX has to offer…. You can still just simply throw shots into the timeline to build, without using any of the metadata features of it.
Skimming gets you through your footage very quickly so quick “on the road” edits are easy in FCPX
I put all narrative elements in my primary and add Broll as connected clips, holding the “tilde” key ~ will temporarily disable any clip connections to the primary which means you can roll without any other clips moving.
I find X extremely fast for news style cuts.
Steve Connor
‘It’s just my opinion, with an occasional fact thrown in for good measure” -
Nicholas Kleczewski
February 4, 2013 at 4:58 pmPossibly even quicker than making new Timelines or Projects as they are actually called would be to make range selections or even multiple range selections and hit Opt-G making Compound Clips that now become your packages to more quickly pull from in your news story beats. You can really blast ass with this method when blasting ass is needed.
Director, Editor, Colorist
http://www.trsociety.com -
Bill Davis
February 4, 2013 at 9:03 pmHere’s the thing.
I’m a huge proponent of editors gritting their teeth and learning the unique X workflow – rather than concentrating on the shortcut ways to use a subset of it’s structure to collapse the process down to the essential elements of just getting out a really fast edit.
Why? Because to condition yourself to use the fastest part of a process sequesters your understanding of all the tools the program provides you. And if you do that – you delay your knowledge of when the new tools can make your work incredibly easier, and you won’t have conditioned your editing brain to the new operations and keystrokes as reflexes.
Essentially, if you’re shooting a one person talking head in the field – YES just working a “timeline edit” might save you minutes. And I fully understand that in a breaking new situation, minutes might count a LOT. But you won’t always be on deadline. And I think it’s important not to stop there in your learning this tool.
Heck, today’s reporter stand up with one actuality and B-roll gig might be today – but tomorrow it might be 3 days with nine interviewees generating hours of content and then you’re in the Hotel Room trying to find just the best of ALL THAT footage – your time spent learning all the subtle keystroke efficiencies and the power of the keyword library might potentially save you DAYS in post.
Again, X “can” be made to work like a more traditional editing program if that’s what you concentrate on. But it ALSO can work like a new more data and search centric editing program – and there’s massive power lurking under it’s hood but you only get to that power IF you take the time to learning the whole process.
I guess I’m arguing that sure, it’s easier to learn just what you need to do to make the kind of work you used to do somewhat faster.
But it’s way more powerful to learn ALL that the program can do, so that you can decide when to employ which elements of it’s structure that are best for various kinds of editing.
And I’m sensitive to seeing so many people come to X and the (very natural) first questions they ask are the ones related to how it does what their OLD software did.
But X is NOT your old software. It’s new software. And the power of the new approach means you must move mentally and emotionally out of the way you once DID things – and move along to how you might use it’s tools to do exciting new things.
I’m remembering Charlie posting about getting home early from his BBC editing and his being surprised at that. That resonated with me because I had similar experiences. The funny thing is that while I was learning X for a while I was worried that because I was spending more time BEFORE my timeline work, it would ADD to my “to do” list and make me slower. But the reality I experienced was that the bit of extra work I did in the Event Browser, was already building my edit in ways I didn’t fully understand – and typically led to leveraged efficiency that was making HUGE gains in my actual assembly and editing and revising and perfecting process – so much so that I was getting my overall projects done way faster.
It’s not an intuitive feeling, because we’re all really well conditioned to think that the “real editing” only starts when you get to the timeline.
But in X, once you learn it’s ways, you’re often doing REAL editing in the Event Browser and keyword collections – not just prep. And so when you get to the timeline, you already have FOCUSED your edit thinking in so many meaningful ways, that the assembly process can sometimes be so fast that I find myself surprised that I’m actually DONE with an edit after a very few minutes on the timeline.
That’s totally counter to my conditioning with Legacy editing where the building of the story only began when I started dropping clips on the timeline and building my edit.
I know I sound like a broken record, but you really do kind of have to know this tool pretty well before you begin to see why it’s so powerful for exactly the kind of “distill a body of material to it’s essence and arrange it and output it all FAST” process which kinda describes the fast moving world of visual information management today.
And heck, if you understand the overall X workflows, THEN it’s possible to dump as much of that as you need and just rock the Storyline by itself to meet an insane deadline.
I just wouldn’t train myself that way. It’s way too limiting, in my view.
FWIW.
Charlie Austin
February 5, 2013 at 1:02 am[Bill Davis] “But X is NOT your old software. It’s new software. And the power of the new approach means you must move mentally and emotionally out of the way you once DID things – and move along to how you might use it’s tools to do exciting new things.
I’m remembering Charlie posting about getting home early from his BBC editing and his being surprised at that. That resonated with me because I had similar experiences”
I assume it’s another Charlie… 🙂 In any case… I agree with what you’re saying with one caveat. In my case, I didn’t have the luxury of time to learn all the intricacies of X before I started cutting with it. It was better for me to learn how to get X to do what I was used to doing, even though I wasn’t using X the way you’re “supposed” to use it. I needed to get stuff done right away. Over time, as i’ve gotten used to it, I’ve started to do more things “the X way”, whatever that really means.
The really cool part of X for me, is that you can work lots of different ways. You can move stuff around willy nilly like FCP 7, you can have the timeline behave in a very Avid like way using storylines, it’s pretty versatile really. That, to me, is the X way. And if learning to use it means you need to get it to act in a more familiar fashion initially, then I think that’s what you should do.
I feel that saying “it’s a whole new way of editing that you must learn!” can be counterproductive. In many ways it is, but in many way it really isn’t either, and you can make it work in whatever way suits you, digging deeper as you get going. Well, unless you want fixed tracks. Then you’re SOL. 😉
~”It is a poor craftsman who blames his tools.”~
Neil Goodman
February 5, 2013 at 2:43 am[Bill Davis] “Import and work FIRST in the event browser. Do NOT go straight to the timeline as you are used to in FCP7.
To do so robs you of much of what’s efficient and special about X.”i dont get it? whats to say anyone worked that way in FCP 7.
In FCP 7, i did all my work in the bins too, before starting to cut something. Doesnt everyone? I dont know many people who just whack a ton of clips in a timeline and figure out in&outs/ markers/ etc later. Who works that way? Sure things get trimmed, chopped and screwed as you go but thats editng, no matter the app.
Pretty much standard practice there Bill, no matter the app. If you used to work that way in 7, maybe thats why you think X is such a revolution.
Neil Goodman: Editor of New Media Production – NBC/Universal
Bill Davis
February 5, 2013 at 4:04 am[Charlie Austin] ” assume it’s another Charlie… 🙂 In any case…”
Wasn’t that you? I cuulda sworn…
Anyway, I get what you’re saying, but I just keep feeling like I’m getting more and more efficient with X – and one way is that the more time I spend with work in the event browser, the less time I’m spending in the storyline thereafter.
I seem to be building skills in each that leverage efficiency in the other.
In fact, day before yesterday I had a bunch of radio spots to voice and deliver for an ad agency I do work for pretty regularly.
I spent about 15 minutes in the VO booth, with the usual mistakes, re-takes and alternates in the resulting sound file. What happened next was kinda interesting to me. After I’d used the Event Browser to dump the dreck with REJECT – range trimmed the good takes quickly, but with a practiced “feel” for leaving the right amount of pause before and after the actual content – then a review pass through the “good” takes to tag and rate them with 1 to 5 quality keyword ratings – I noticed I had just one “best” take for each, so I clicked on my “5” rated collection. Selected ALL. Plopped them into a storyline.
And when I played back the result, realized that my job of assembling the client review reel was literally DONE at that point. I’d literally editing my entire project in the EB. I Shared them to the client and put the software away.
Period. no storyline editing AT ALL. I’d done ALL my actual editing work right in the Event Browser.
Now obviously audio editing is NOT video editing. But it reminded me that this one way X’s database leverages efficiency really well. Viewing the Event Browser as both first stage editor and QUALITY SORTER simultaneously – can remove tremendous complexity during prep edit. And in my case, I removed so much of the necessary downstream work in the EB that there was literally none left to do in my storyline.
First time THATS ever happened to me working with X!
If the client approves those spots, I have a slate tone clip in my EB to paste-connect to each spot, connect the proper voice ID clip – and BINGO I’m about 3 minutes away from delivery to the media buyer for distribution to the stations in the time buy.
First time I’ve edited anything where my “timeline” work was literally the most insignificant part of my workflow.
Thanks to how “X” works.
Again, I know audio editing and video editing are two different beasts. But the idea remains. The power of X is in the INTERACTION of the EB and the Storyline. And most often, understanding one without understanding the other obscures concepts that truly can enhance your editing experiences.
Not always, not exclusively, and depending you your workflow, perhaps not at all. But the software makes that kind of pre-editing to eliminate complexity from your timeline possible.
To me, my little radio spot edit revealed a good example of how new thinking can drive a lot of new efficiency – and it was made possible purely though my understanding how X is designed to work.
FWIW.
