Activity Forums Apple Final Cut Pro Legacy How do I replace Media?
  • How do I replace Media?
    Posted by Eric Klassen on September 25, 2006 at 3:46 pm
    I have several hard drives with hundreds of one hour quicktime files. The naming for these clips have been changed for batch list purposes. There were previous edits with the old names. When I go to reconnect the media, none of the clips can be selected. What do I do? My only thought is to import the new named media and replace it in the edits. I’ve never done this before. How do I keep the old edits and switch out the media?
    Eric
    Jerry Hofmann replied 20 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 25, 2006 at 3:56 pm
    If you can remember which source clips go where and what you renamed them, you should be able to reconnect them anyway. There is a checkbox to turn off in the reconnect dialog box. (the same name – turn it off) then you’ll be able to connect to the media which has been renamed. Course, you have to know which connects to what…
    Otherwise, you can import the renamed clips, and re edit them in.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
