Activity › Forums › Adobe Premiere Pro › How do I – render to FLV under 2GBs? best quality comes out at 2.7gb
  • How do I – render to FLV under 2GBs? best quality comes out at 2.7gb
    Posted by Nige Morgan on December 31, 2012 at 10:56 am
    Hi
    I’m trying to put a film (83min) I’ve made on IMDB, but IMDB has limits and here they are.
    File must be FLV, under 2GB, upto 1280x by 720x
    Im using premiere pro cs 5.5
    I can do the setting to 1280 x 720, and FLV but the film size comes out at 2.7 GBs.
    I want to keep it as best quality as I can.
    Question – How/Is there a way of keeping it high quality and compressing it to 2GB rather then 2.7GB
    THanks Nigel
    Nige Morgan replied 13 years, 8 months ago 3 Members · 3 Replies
  • Gary Milligan
    December 31, 2012 at 5:18 pm
    If lowering the Bitrate to get the file size below 2GB doesn’t give you the quality you want, or maybe reducing the frame size to 960 x 540, or a combination of both, then maybe you can split the movie into two parts.
    HTH
    Gary
  • Chris Tompkins
    January 2, 2013 at 12:33 pm
    Keep inching the data rate down until it falls just under the 2GB size.
    That’s all you can do.
    Chris Tompkins
    Video Atlanta LLC
  • Nige Morgan
    January 5, 2013 at 2:56 pm
    thanks that worked great, i’ll look up what biterate even means im guessing something to do with quality
