Activity Forums VEGAS Pro How do i render in 16:9 ?
  • How do i render in 16:9 ?
    Posted by Simon Wimpenny on June 16, 2006 at 4:38 pm
    I have some footage filme don my HC1 that i have captured to my PC as DV in 16:9
    What setting do i use to convert it to MPEG 2 but in 16:9 ? if i use widescreen it seams to stretch the picture vertically and if i use normal DV it doesnt seam to show all the picture
    Any help appreciated
    cheers
    si
    Jerry Waters replied 20 years, 3 months ago 3 Members · 3 Replies
  • Dan Achatz
    June 16, 2006 at 8:35 pm
    NTSC 16:9 widescress will look like 4:3 with tall skinny people. The reason for this is that a 16:9 NTSC monitor streches the picture sideways to fill the screen.
    You may have noticed that some people who have 16:9 TV’s always have short fat people on the screen. That’s beacuse they are stretching a 4:3 image sideways to fill the screen.
    If you are rendering an MPEG 2 for DVD, just select NTSC widescreen and it will render out for NTSC (Note in Vegas you need to select include audio on the audio tab. DVDA defaults to include audio). Your DVD player should letter box the signal or play it full screen depending on your set up. You will need to make sure that your DVD player and TV are also set for widescreen.
    If you are rendering as a WIndows Media file, Real Media, or Quicktime, you want to choose a 16:9 format or you may want to consider choosing a custom size to render to, like 640 x 360.
  • Simon Wimpenny
    June 17, 2006 at 8:15 am
    great thanks for the help, that clears thingsup.
  • Jerry Waters
    June 18, 2006 at 12:59 pm
    Try the widescreen NTSC template. It works fine.
    JerryW
