Activity Forums Adobe After Effects How do I remove glass reflections from clothing
  • Eric Santiago
    October 29, 2019 at 12:07 pm
    The usual, track and keyframe mask the problem areas.
    It will be tough since those are very quick camera moves.
    Lucky the bathrobe is dark enough and easy to recreate.
  • Jawad Zafar
    October 29, 2019 at 1:56 pm
    Hi!
    Thanks a lot for your response.
    I will not be able to track this bathrobe because it’s black and in dark and doesn’t have texture in it. How can I track it accurately?
    How masking the problem areas can fix the issue?
    What do you mean by recreating? Do you mean paint the bathrobe frame by frame?
    Waiting for your response.
