Activity Forums Apple Final Cut Pro Legacy How do I remove frames from a clip?
  • How do I remove frames from a clip?
    Posted by Tom Fino on March 6, 2017 at 7:35 pm
    Is there an easy way to remove a set proportion of frames (i.e. every other frame or every tenth frame, etc.) from a clip without doing it manually one frame at a time? Thanks.
    Nick Meyers replied 9 years, 6 months ago 3 Members · 2 Replies
  • Tom Matthies
    March 6, 2017 at 9:29 pm
    Change the speed to a faster rate?
    Not my monkeys. Not my circus.
  • Nick Meyers
    March 7, 2017 at 5:27 am
    the non-manual approach is to speed the clip up, and turn frame blending OFF.
    then FCP wil simply drop frames
    speeding up to 110% would remove every 10th frame (although i haven’t really done the figures)
    my guess is it would be a bit hit and miss, not entirely accurate.
    it;s possible t do it manually, but not frame-by frame
    lets say you wanted to very accuraltey remove every tenth frame.
    on a track above your clip place 9 frames of slug, et 1 frame of text
    copy that and paste at the end of itself
    then copy those 2 instances and do the same, and keep doing this till you’ve covered the entire clip (wont take long).
    now do a search for “slug”. you may have to use the find between in and out points function
    find all, an delete all the slugs
    select all the 1 frame text left over
    hold shift and drag them down over the clip, overwriting every tenth frame, then delete
    now take whats left of the clip, drag into the canvas, and all those bits will be edited back into the timeline.
    nick
