Activity › Forums › Adobe Photoshop › How do I remove background from bulk images
  • How do I remove background from bulk images
    Posted by Nikita Papastamatis on August 16, 2016 at 12:02 pm
    Hi all,
    I have taken photos of agar plates for my science experiment. An example of the photos is below. There are 50 of them per day which makes around 400 photos all together. I would like to know how to remove the background. I would prefer if it could be done in one go without having to select the area i want to keep and make a new layer for every photo. Is there any way???
    Thanks for you help
    Nikita 🙂
    Kalleheikki Kannisto replied 10 years, 1 month ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    August 16, 2016 at 2:52 pm
    If the placement is exactly the same in each photo, you can do it with an action, selecting the same circular area, iverting the selection and filling with white.
    If the plates are not in the same exact location, it not going to be so simple. In theory you could pre-crop the images somewhere close to the plate, bring them in to a single document and use the “align layers” feature to try and automatically align them in the same spot, which may or may not work. For any layers that didn’t align automatically, you’ll have to align manually. After which you can use an action to select the area and fill the background, then select next layer down, repeatedly. When done, Photoshop can export layers as individual files.
    Senior Graphic Designer
