Activity Forums Avid Media Composer How do I remove an effect if…?
  • How do I remove an effect if…?
    Posted by Kim Winn on February 22, 2009 at 6:10 pm
    How can I remove an effect on a clip that has transition at the in and out point? The remove effect will remove the transition (to whichever side of the clip is closest), then I can remove the effect on the clip (and then have to replace the transition).
    Is there a quicker way?
    Michael Hancock replied 17 years, 7 months ago 3 Members · 3 Replies
  • Michael Hancock
    February 22, 2009 at 9:00 pm
    1. Go into segment mode, select your clip, hit delete.
    2. Go into effect mode, select your clip, hit the Remove Effect button (delete may work here too).
    3. Make sure you’re position indicator isn’t near either transition and hit Remove Effect. If your position indicator is too close to the transitions it removes them first. If you’re basically in the middle it removes the effect on the clip.
    Michael
  • William Busby
    February 24, 2009 at 9:47 pm
    Thanks for that Michael. All these years I’ve been doing a roundabout workaround.
  • Michael Hancock
    February 24, 2009 at 9:51 pm
    No problem. Glad it helped.
    Michael.
