Activity › Forums › Adobe After Effects › How do I remove an actor from a video?
  • How do I remove an actor from a video?
    Posted by James Patrick on October 13, 2012 at 12:51 am
    I have a video where I need to put the actor into a different location, so I basically need to cut the person out of the video and paste them into a new video. I’m guessing this would be done with rotoscoping or are there any new features in after effects or photoshop that may make it easier or different types of software? also do I need to go frame by frame cutting them out? if you could provide any insight or links to tutorials that would be great.
    John Cuevas replied 13 years, 11 months ago 2 Members · 1 Reply
  • John Cuevas
    October 13, 2012 at 1:08 am
    Since CS5 the Rotobrush is really the quickest way to roto someone with AE. Check out this tutorial from AdobeTV to get started.
    Creative Cow Tutorial
    Then his a google search for Rotobrush tutorials.
    I’ve watched the first one and it’s pretty good, but you may want to check out the help afterwards, rotobrush isn’t totally intuitive. After you check that some of that stuff out, if you have any questions come back.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
