Activity › Forums › Adobe Illustrator › How do I Recreate a Logo in Illustrator
  • Jonathan Ziegler
    April 16, 2014 at 4:11 pm
    The easy way is to create a single line of dots with one dot at the center. Group the line, then select the rotate tool and reset the center point to be the “center dot” created above. Option-rotate to duplicate the row of dots using the center dot as a fulcrum, then use repeat to make as many as you like. When done, ungroup a couple times and delete the center dots. Done. 🙂
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
