Activity Forums Maxon Cinema 4D How do I put different textures on an caps and sides of an extrude.
  • How do I put different textures on an caps and sides of an extrude.
    Posted by Chad Demoss on August 18, 2020 at 12:17 am
    I was watching a video on something else and noticed someone had 2 textures on an extrude. one for the cap and one for the sides of it. how do I do this?
    Chad Demoss replied 6 years, 1 month ago 2 Members · 5 Replies
  • Sam Treadway
    August 18, 2020 at 1:08 am
    In C4D S22 these are exposed in a tab but prior to that you’d have to remember them or reference the manual
    You need to assign a selection to each material.
  • Chad Demoss
    August 18, 2020 at 3:32 pm
    Thanks Sam
    I’m still in R19 so I used the abbreviations you posted in the screengrab. the link to the manual I can’t seem to find the list of the polygon selection abbreviations. that screengrab you posted where did that come from R22?
  • Chad Demoss
    August 18, 2020 at 3:49 pm
    The caps and bevel work but “S” for shell isn’t working.
  • Sam Treadway
    August 18, 2020 at 4:37 pm
    For the sides just leave the selection field blank and make sure that texture tag is listed first.
    https://www.youtube.com/watch?v=E7MWhH-wyIE
  • Chad Demoss
    August 18, 2020 at 5:03 pm
    Thanks again.
    After I posted this I was fiddling around and moved that texture to the front and that did indeed fix the issue.
