Activity › Forums › Maxon Cinema 4D › How do I properly bake a texture in Cinema 4D?
  • How do I properly bake a texture in Cinema 4D?
    Posted by Zach Meissner on March 21, 2014 at 3:46 pm
    I’m trying to bake a texture into a model, using the ‘bake object’ command under ‘objects’. This is how i see it in so many tutorials, but i’m not getting the same results, my results are terrible.
    Here is the way it should look:
    But every time I bake it, it comes out looking like this:
    Am I missing something?
    http://www.lab316.com
    Adam Trachtenberg replied 12 years, 6 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    March 21, 2014 at 9:47 pm
    I don’t think the bake object command supports alpha channels. Use the bake texture tag instead. Check the “use polygon selection” box, alpha channel, and whatever other channels you want. If you render to a single file you may have to pick the layer sets manually when you set up the new texture.
