Activity Forums VEGAS Pro How do I prevent Vegas from stretching my AVI video?
  • How do I prevent Vegas from stretching my AVI video?
    Posted by Ben Hen on February 26, 2010 at 7:26 pm
    I have a video that is stretched every time I render. The project is 720×480.
    If I render the AVI with Template: NTSC DV, which is Uncompressed, it doesn’t stretch it. Output size is set to 720×480. The resulting video, according to Media Player Classic, shows video size as 720×540 – and it looks right, even though that’s not the setting I chose. (And the “Stretch video to fill output…” box is NOT checked.)
    However, if I use xVid to compress it, and set Frame Size: 720×480, it comes out stretched, and is 720×480. If I set the output size to Project Size, it still comes out 720×480. If I use a CUSTOM SIZE of __720x540__ , which I assume is the correct size, since it looks right at this size, 724 x 544 !!!! And I can’t get it NOT to do that.
    Can anyone help me? I’ve rendered the first 2 min. for hours now, trying to get it NOT to stretch. And maybe someone can explain why my project, at 720×480, renders at 720×540, when I don’t tell it to do that – and it looks right at that ratio.
    (frustrated)
    Theo Van laar replied 16 years, 6 months ago 2 Members · 4 Replies
  • Theo Van laar
    February 26, 2010 at 7:46 pm
    What is the pixel/aspect ratio (PAR) of your footage. And what is the PAR of your project? And the PAR of your rendering settings?
    Theo
  • Ben Hen
    February 26, 2010 at 7:52 pm
    PAR of Project: 0.9091 (NTSC DV)
    PAR of render: 0.9091
    The project contains still photos and videos. The videos PAR is 1.2121 (NTSC DV Widescreen).
    Is that a clue? What do I do about it?
  • Ben Hen
    February 26, 2010 at 8:29 pm
    With your help, I was able to render correctly. I reset the Project PAR to be the same ratio as the videos inside it. Then when I render, I set the PAR to 1.0.
    Thank you!
  • Theo Van laar
    February 26, 2010 at 8:47 pm
    People who can solve their own problems are the best! Congratulations.
    Theo
