Activity Forums VEGAS Pro How do i override the effects in one clip when effect is applied to media
  • How do i override the effects in one clip when effect is applied to media
    Posted by Chris Morley on July 11, 2011 at 3:05 pm
    I have applied some effects to a long media clip that is part of a multi-cam edit. If one of the clips from that media doesn’t need the effects that i’ve applied how do I go about bypassing the media effects?
    Chris.
    Aleksey Tarasov replied 15 years, 1 month ago 3 Members · 3 Replies
  • Larry Brewer
    July 11, 2011 at 3:33 pm
    There may be more than one way to accomplish this, but my method would be to use track FXs. Place every event that you want the FX applied to on a single track, apply track FX to that track. Those you don’t want FX applied to, place on a different track.
  • Chris Morley
    July 11, 2011 at 4:30 pm
    Hi there. Thanks for the reply. The thing is that i’ve got two media streams on one track, having just used the multicam editing tool to edit the two, so i can’t easily get all the clips (Events, to introduce the correct terminology)onto two separate tracks. There are around 50 clips per media residing on the one track.
    Any other ideas?
    Chris.
  • Aleksey Tarasov
    July 11, 2011 at 6:12 pm
    > “Any other ideas?”
    Use Subclips
