Activity › Forums › Apple Final Cut Pro › How do I open .vid extensions in Final Cut Pro X
Posted by Gina Miller on October 16, 2016 at 5:43 pmHow do I open .vid extensions in Final Cut Pro X?
Thanks! Gina
Patrick Donegan replied 9 years, 11 months ago 3 Members · 6 Replies -
Oliver Peters
October 16, 2016 at 6:39 pmI doubt you’ll be able to. What source created this file? If you can get it open, you’ll probably need to convert it to a file that FCPX can read. What other apps do you have that can open it? Does it open and play in VLC? For conversion, you might try QuickTime Player Pro, MPEG Streamclip or Edit Ready.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Gina Miller
October 16, 2016 at 6:47 pmI can open it with Quicktime and VLC. The files were from a stock site so I don’t know what the original source was.
Oliver Peters
October 16, 2016 at 7:41 pmIf QuickTime 7 can open it, then the free MPEG Streamclip *should* be able to convert it.
– Oliver
Orlando, FL
Oliver Peters
October 16, 2016 at 7:42 pmPS: just for grins you might try seeing if, by changing the file extension to .mov, FCPX can be “tricked” into opening it.
– Oliver
Orlando, FL
Patrick Donegan
October 17, 2016 at 4:43 amI was just going to suggest that!
FCP X 10.2.3 – user since FCP 1.25
iMac mid 2011, MBA mid 2012
iPhone 4
HVX-200, Shure wireless mic
Miller Solo tripod
Advanta-Jib
