Activity › Forums › Adobe After Effects › how do I open a windows AEP on a Mac AE v.9?
Posted by Robyn Rhodes on September 11, 2009 at 5:48 pmSimple ?
How do I open a Window’s AEP file v.9 on a Mac with AE v.9?
Robyn Rhodes
I’m only half the thing I say I am, the other half are me.
Jason Brown replied 17 years ago 5 Members · 6 Replies -
Robyn Rhodes
September 11, 2009 at 6:02 pmNo not a freaky Friday gotcha question. But if I think of one I will post it:)
Oh is it that simple? I assumed it would be incompatible.
I am a “cross platform AEP file opening ignoramus”.
Robyn Rhodes
Steve Roberts
September 11, 2009 at 6:53 pmDon’t forget plugins. If the original project used third-party plug-in effects, Windows versions of those plugins need to be present on the Windows box.
Sometimes Mac & Windows versions of a plugin are sold together, sometimes separately. It depends on the plugin.
Todd Kopriva
September 11, 2009 at 6:57 pm“Cross-platform project considerations”
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Brian Deviteri
September 11, 2009 at 7:17 pmDepending on what you are actually working on within AE, I would also suggest you ask for a compression of the last version they are sending for own reference. Sometimes this helps if effects don’t properly transfer from one platform to another.
Another BIG deal is fonts. Again, not sure if you’re dealing with them, but a lot of times you will have to substitute them, even if the same font is installed on your machine. A quirk between different operating systems (and sometimes within the same OS environment) is that each machine will sometimes “see” the same fonts slightly differently, especially when dealing with fonts that have multiple family options. You’ll get the font error messages, but if you have a reference clip you can easily choose the proper substitute and just double-check everything lines up the way it should.
Robyn Rhodes
September 11, 2009 at 7:22 pmthanks all for the help.
have a nice weekend(if you have one;)
r
Jason Brown
September 12, 2009 at 12:34 amJust FYI…I’ve had issues with Adobe Encore projects going from Win to Mac
