Activity Forums Adobe After Effects How do i not get round spline points in a mask?
  • How do i not get round spline points in a mask?
    Posted by Miles Blow on January 16, 2012 at 3:07 am
    Hi sometimes when Im creating a mask in ae I klick points with the mask tool (g) and I get the points with the 3 point spline(i think they are called) points that are really annoying when trying to mask out straight objects…what am I doing wrong?
    Miles
    Miles Blow replied 14 years, 8 months ago 3 Members · 3 Replies
  • Dan Fredley
    January 16, 2012 at 5:30 am
    You need to be careful to click straight without dragging. If you accidentally create a “round point”, you can stop and option/alt+click to change it to a “straight point” , then continue masking as normal.
    Dan Fredley
  • Tudor “ted” jelescu
    January 16, 2012 at 7:36 am
    You can also find the convert points tool to break the bezier points, or convert them to linear, under the pen tool, the last one that looks like an angle.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Miles Blow
    January 16, 2012 at 9:37 am
    Hi Guys…. thanks for that i will try all those!
    Thanks Miles
