How do i mask optical flares led wall with a shape?
Hi! I’ve re-created Andrew Cramers scene. But I can’t find the solution on how to mask lights individually.
I’ve found only flicker mode but it’s not as flexible as i need. I’ve tried to achieve same result using CC ball action but failed.
I’m sure this has a super simple solution, but I just can’t figure it out.
Any advice?Thanks & Cheers
Olk
