Activity Forums Maxon Cinema 4D How do I make this?
  • How do I make this?
    Posted by Ryan Paterson on August 23, 2015 at 10:36 pm
    The main shape, just the outer shell. The inner part seems simple, but I cannot for the life of me figure out how he got those awesome curves on the connecting pieces. Any ideas?
    Ryan Paterson replied 11 years ago 3 Members · 4 Replies
  • Adam Trachtenberg
    August 24, 2015 at 3:58 am
    That’s probably made with some kind of skinning function. The Cinema equivalent is the metaball object. For something like this I would create a platonic primitive, make it editable, select all the edges, and run the Mesh>Commands>Edge To Spline function. Then drop the resulting spline in a metaball object and play with the metaball settings to get the shape you want.
  • Brian Jones
    August 24, 2015 at 8:55 pm
    I get pretty good results with x-particles skinner
  • Adam Trachtenberg
    August 24, 2015 at 9:37 pm
    Yeah, a lot more versatile than the built-in metaball object.
  • Ryan Paterson
    August 24, 2015 at 10:20 pm
    Just tried with the metaball object and got a reasonable facsimile of it. I’ll throw it into XP when i get home. I knew there had to be a simple solution for this, thanks!
