Activity › Forums › Adobe After Effects › How do I make the tracker lines disapear for a bit
  • How do I make the tracker lines disapear for a bit
    Posted by Joshua Green on May 5, 2013 at 6:14 am
    simply put, i just want to make the tracker points and lines invisible for a bit to see what I’m doing. I’m working on something and i need to be able to zoom in and see if the tracker is spot on or not but at some points there are so many tracker points in the way i can’t see if it’s right or not.
    thank you in advance
    Roland R. kahlenberg replied 13 years, 5 months ago 2 Members · 1 Reply
  • Roland R. kahlenberg
    May 6, 2013 at 7:43 am
    Look at settings in –
    Prefs>Display>MotionPath
    I set this to No Motion Path when tracking.
    HTH
    RoRK
    Intensive mocha & AE Training in Singapore and Other Dangerous Locations
    Imagineer Systems (mocha) Certified Instructor
    & Adobe After Effects CS6 ACE
