Activity Forums VEGAS Pro How do I make the Text Media Edit box bigger?
  • How do I make the Text Media Edit box bigger?
    Posted by Tor Wong on April 4, 2008 at 2:48 pm
    Hi, so when I make a new Text Media event and look in the Video Media Generators window in the Edit tab, it shows a small text window-in-a-window that takes up but a small part of the whole window. No matter how big I resize it, the area where it says “Sample Text” stays small and isn’t fully viewable.
    (This is difficult because it makes me scroll around a lot more with subtitles than I would have to if the text field was bigger.)
    Is there a solution/workaround to this? I’m in Vegas 8 and these are for simple titles, so I don’t need the Pro titler.
    Gratitude in advance.
    Tor Wong replied 18 years, 5 months ago 2 Members · 5 Replies
  • Tor Wong
    April 11, 2008 at 3:53 pm
    Hi again, anyone know a way to do this? Very strange if it’s not possible, seems to be a significant UI omission.
  • Theo Van laar
    April 11, 2008 at 7:39 pm
    I don’t think that you can change the size of this text box under the EDIT tab (although I haven’t tried to change the monitor resolution). But a simple workaround could be that you create your text in a smaller font and only after finishing your text, select all the text (Ctrl A) and change the font to the size you would like to use in your project.
    Theo
  • Tor Wong
    April 13, 2008 at 6:51 pm
    Thanks for the reply, Theo! Alas, that’s not a practical workaround for me, because I work with many subtitles, and to do that on each one is inconvenient — I need to see how the full-size text will fit on the preview monitor.
  • Theo Van laar
    April 13, 2008 at 8:39 pm
    Then you will have to use the scrollbar…
    Maybe Sony can change this in Vegas 9?
    Theo
  • Tor Wong
    April 14, 2008 at 12:54 pm
    I hope this can be improved, yes — it’s a UI limitation which doesn’t make sense, since the overall window can be expanded.
