Activity Forums Maxon Cinema 4D how do I make objects blurry without using depth of field?
  • how do I make objects blurry without using depth of field?
    Posted by Chad Demoss on February 6, 2019 at 3:21 pm
    I need to make some objects blurry and other objects at the same distance not blurry. I would just make two separate videos but some of the objects will animate in front and behind the non blurry objects. Or is there a way of excluding objects from depth of field?
    Chad Demoss replied 7 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    February 7, 2019 at 7:38 pm
    haven’t heard of any render engine that will allow you to exclude an object from DOF I would think compositing in post would be the way.
  • Chad Demoss
    February 8, 2019 at 10:37 pm
    thanks Brain
    I have rings that go in front and then behind of the blurry spheres so I cant do it in after effects without a lot of work. I don’t really even want depth of field just some objects blurry and some not.
