Activity Forums Maxon Cinema 4D How do i make “Matrix Extrude”
  • How do i make “Matrix Extrude”
    Posted by Chrisco on April 28, 2006 at 12:00 pm
    Hi Guys
    Im followinf a tutorial, whcih i think is a v7 or 8 tut. and it tells me to make a platonic and make it editable….which i have done. it then says go to Structure>Edit Surface>Matrix Extrude, but when i go to Structure, there is no Edit Surface and the Matrix Extrude is not selectable. What could i be doing wrong?
    Chrisco
    C4D r9
    Chrisco replied 20 years, 5 months ago 2 Members · 3 Replies
  • Samir Kharchi
    April 28, 2006 at 12:14 pm
    you must be in polygon mode and edit a polygon object. Then click the right mouse button in the editor view and there you go with the Matrix Extrude tool (or use the menu)
  • Chrisco
    April 28, 2006 at 12:33 pm
    But how do i enter into polygon mode?
  • Chrisco
    April 28, 2006 at 12:37 pm
    no worries.. i found the polygon tool.
    im sure i will be back soon with another problem.
    thanks for your help
