Activity Forums Maxon Cinema 4D How do I make Laser Beam?
  • How do I make Laser Beam?
    Posted by Stuart Paciej on December 7, 2011 at 9:18 pm
    Hello all,
    I want to make a laser beam that will cast intense light onto objects and for the beam to be visible at the very least. Also to reflect off mirrored objects would be great. E.g. a mirror in its path set at 45º should mean the light changes angle by 90º.
    I am playing with a narrow beamed spot light using visible light, but this doesn’t reflect and continue onwards at 90º.
    I also tried volumetric light through a shaped gobo (hole) which has the same problem.
    –> So ideally some help on the above would make me happy
    BUT for an encore if you can answer this:
    In an ideal world to act like a prism comme ça: https://www.youtube.com/watch?v=qKBu5HVuFQM
    …I am aware that the reference may well be live action so perhaps its not possible 😉
    Thanks in advance!
    Stuart
    Adam Trachtenberg replied 14 years, 9 months ago 2 Members · 3 Replies
  • Adam Trachtenberg
    December 8, 2011 at 5:04 am
    You would have to use caustics to have the light bounce, but I don’t think that actually works with volumetric light (can’t remember for sure).
  • Stuart Paciej
    December 9, 2011 at 10:22 am
    Thanks for replying Adam, I will have a look at caustics, but that word puts fear in me as I seem to remember they take aeons to render and to get right 🙂
    I may also check out this 2.5D plugin which seems to show promise and you / anyone who ends up on this post may find interesting:
    https://www.tools4d.com/?page_id=905
  • Adam Trachtenberg
    December 10, 2011 at 3:45 pm
    Looks like a cool plugin, but there are lots of ways you could fake the effect — like using separate visible lights for each “bounce”.
