Activity › Forums › Boris FX Particle Illusion › How do I make Keyframes using PI?
  • How do I make Keyframes using PI?
    Posted by Chrissibollen on August 20, 2006 at 6:19 am
    I wonder how I can make such effects like they’re shown in the sample movies of PI using Keyframes.Where’s that option in PI?
    Could you please be so kind and give a beginner a little step-by-step tutorial of how to do such a keyframe-effect :)?
    That would be great!
    Chrissi
    Elvis Deane replied 20 years, 1 month ago 3 Members · 7 Replies
  • 7 Replies
  • Bill Hamell
    August 20, 2006 at 3:51 pm
    Chrissi,
    Open up the manual in PI SE or PI3 go to Tutorial 2 select “The Graph Window” and read through the next few steps. I think you will find what you need there.
    Bill
  • Chrissibollen
    August 20, 2006 at 4:36 pm
    Hmm,sorry,but I did not find what I was looking for.
    Taking keyframes from footage is not possible,is it? I mean for example,making a canvas round a guy sitting in front of a green wall and cut him off the footage-is this possible? Or do I need another software like After Effects?
    thanks,
    Chrissi
  • Bill Hamell
    August 20, 2006 at 4:58 pm
    Chrissi,
    Ahh… you mean Chroma key not key framing. 🙂
    The ability to choose a color to make transparent, yes another program like After Effects would be better, some NLEs will allow you to key out a particular color so you may already be able to accomplish this.
    Bill
    Cinematographers bring Shadow to Light
  • Elvis Deane
    August 20, 2006 at 5:43 pm
    You can do this in pI with the Transparency settings of a layer, but it’s pretty rough. If you double-click the T icon on the layer, you can check up to three colours to key out by selecting the boxes under Transparent Color Selection.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
  • Chrissibollen
    August 20, 2006 at 6:28 pm
    hmmm,did I get that right:
    I can make a movie in front of a greenbox, then cut out my shape (like its shown in the PI sample movie 2006) and fill that shape with a particle effect,playe the layer with my body (for example) over that again in order to make my body disappear with a particle effect? Is that possible by using those transparency options?
    thank you so much,I’m pretty n00b,I know 😉
  • Chrissibollen
    August 21, 2006 at 9:08 am
    I found that in Dean’S tutorials:
    “You’ll need to begin by bringing in some footage as a background. Here we have an “actor” who was shot against a green screen. In my compositing program, I’ve used the keying tools to remove that green screen, and then saved the clip out as a sequence of images (PNG) with an alpha channel. So now when we import that sequence into particleIllusion, all we have is an actor standing against a transparent background.”
    This is exactly what I mean-you call it “compositing program”-can I do that with i Movie? Or is there a freeware-tool?
  • Elvis Deane
    August 21, 2006 at 5:59 pm
    You can do keying using those transparency options. In the particleIllusion help file, go to Tutorial 4 and Layers>Transparency. That explains how to do simple keying withing particleIllusion. It’s not quite as good as the tools that you would find in a compositing program, but it works okay. You’ll basically just pick a few different types of green from the footage you shoot of yourself in front of the green background, and use the sliders to remove those shades from the background.
    I don’t think you can do any keying effects in iMovie without some plugins. There’s one here that costs $3.50 but doesn’t look like it has a smoothing tool so it probably isn’t even as good as what particleIllusion can do, and eZedia has one that costs a bit more and does have some smoothing capabilities. Not sure how good either of these are, but they might be worth a look. I found those with a very quick look, so you may want to do your own search to see if there are any free ones.
    Elvis Deane!
