Activity Forums Adobe After Effects how do i make camera angles static from one to another, instead of camera animating movement?
  • how do i make camera angles static from one to another, instead of camera animating movement?
    Posted by David Lieberman on March 17, 2007 at 4:36 pm
    hi everyone,
    im trying to get several different angles of my compositions on one camera… all i did was set up an angle, skip one frame, and set up another one… but when i set up the 2nd one, there is a movement in the camera, and i want it to simply jump from one angle to the other… is this possible?
    i need this to happen that way because im using tarpcode sound keys, and i want the camera to jump between angles of the compositing in sync to the beat….
    anyone?
    thankx.
    shroomly
    David Lieberman replied 19 years, 5 months ago 3 Members · 3 Replies
  • Mike Clasby
    March 17, 2007 at 6:36 pm
    I try changing the keyframes to Hold keyframes (right click the keyframe>Toggle Hold Keyframe), that should freeze the camera until a new keyframe is reached.
  • Sam Moulton
    March 17, 2007 at 9:32 pm
    id just put different cameras in the timeline. AE will always render the top camera, you can simply adjust the in and out points of the cameras.
  • David Lieberman
    March 18, 2007 at 12:48 am
    thanx a lot mate!!! really helpfull!!!
