Activity Forums Adobe After Effects How do I make background NOT to zoom with camera?
  • How do I make background NOT to zoom with camera?
    Posted by Alex King on December 18, 2010 at 6:12 pm
    Hi there. Newbie here again. I am currently working on a project in CS5 and is pulling my hair out. I have a mask of a map with several other objects, all in 3D and some parent to other footages. The background is a solid color. I then added a camera movement from afar and flies towards the map. After all of this hard work and trial/error, the action is starting to look good.
    The problem?? Now I want to add a new background of an outer space photo ( JPEG ). When I add the photo to my timeline in 3D, I can’t figure out how to make the outer space background photo NOT to zoom in when the camera flies towards my map ( giving the effect of BIG outer space ) It has to be in 3D because the camera angle will move again. The action of adding this new photo also makes other items in the timeline to go a little ” wacky “. I tried placing a keyframe, tried footage replacement, layers, masking, etc.
    Any help will be greatly appreciated. Simple to others, but hard for this newbie to figure out. Thanks
    Alex King replied 15 years, 9 months ago 3 Members · 3 Replies
  • Graham Macfarlane
    December 18, 2010 at 10:45 pm
    If you need the space BG to react to camera turning but not to zooming perhaps the easiest method might be to make the space BG a 3D layer and push it really far away in Z then scale it up to fill the comp. This way when your camera zooms in there wont be much change in the BG but when you turn the camera it will work just fine.
    Graham Macfarlane
    3D animator and VFX specialist
    London UK
  • Henry Cobbold
    December 20, 2010 at 10:22 am
    Dave is always right!
  • Alex King
    December 22, 2010 at 12:55 am
    Thanks for the help folks. Looks like the way to go is to push the Z axis way back and further than the distance of the camera. Another is just to leave the background space in 2D. Any of these will do for me for now.
