Activity › Forums › Adobe After Effects › how do i make a video footage longer
Posted by Hanna Dean on July 6, 2016 at 1:33 amWalter Soyka replied 10 years, 2 months ago 3 Members · 3 Replies -
Daniel Waldron
July 6, 2016 at 1:46 amRight click on the layer and enable time-remapping. This will allow you to “make it longer” by either duplicating frames or using a freeze frame after it ends.
Daniel Waldron
July 6, 2016 at 1:57 amI just noticed you want to extend the fire shot, not the building shot. I should point out that for this particular shot, time-remapping will not look good at all. You either need to find a longer fire clip or create your own fire using a particle system.
Walter Soyka
July 6, 2016 at 2:02 pmFootage can also be looped from the Project Panel in its Interpret Footage dialog without creating a precomp. This will extend the duration of the available footage in timeline panels. If the footage is not actually seamlessly loopable, though, you are certainly better off creating a loop in a precomp.
Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn]
