Activity › Forums › Panasonic Cameras › How Do I Make A Timecode Burn??
  • How Do I Make A Timecode Burn??
    Posted by Bill Thomas on February 15, 2008 at 2:39 pm
    Our previous format was betacam and it was easy to make timecode burns for our clients.
    Now with P2 I’m not sure the best procedure for that. Unfortunately, about half of our work requires that the client get a timecode dub of the raw footage.
    How can I accomplish this with P2?
    Bill
    Jeff Carson replied 18 years, 7 months ago 4 Members · 4 Replies
  • Noah Kadner
    February 15, 2008 at 5:52 pm
    Drop a timecode reader filter onto your footage- assuming you are using an NLE to ingest.
    Noah
    Unlock the secrets of the DVX100, HVX200 and Apple Color. Now featuring the HD Survival Guide!
    https://www.callboxlive.com
  • Dean Sensui
    February 16, 2008 at 11:59 am
    Bill…
    Did your clients just need to see the numbers or do they also need to have an LTC SMPTE signal on one of the audio tracks?
    Dean Sensui — Imagination Media Hawaii
  • Bill Thomas
    February 16, 2008 at 11:02 pm
    They just need to see numbers on the screen to choose shots.
    I know FCP will output a timecode of a Sequence, but I need to have the specific clip timecodes.
    ALso, when I tried that before, it took forever to render the time code!
  • Jeff Carson
    February 17, 2008 at 5:09 pm
    Bill,
    Try changing your sequence RT settings. Most machines can play P2 back with the TC filter in real time. Quality might take a hit, but it should not matter for your purposes. We use a different approach.
    Our process involves dumping all P2 to our AJ1400 HD deck from a long sequence (real time/no rendering/full quality), and simultaneously recording the deck’s TC window to the DVD recorder. This solves the P2 archiving problem, and once the HD tape is captured and the program is cut together, we just dump the P2 clips.
    Dual 3Gb Mac Pro Intel 8 Core, 5GB RAM, OS 10.4.11, QT 7.3, FCP2 6.0.2, CS3, AJA ioHD
