Activity › Forums › Adobe Encore DVD › How do I make a Motion Background menu?
Posted by Jonathan Robinson on May 2, 2005 at 10:03 pmI would like to know how can you make a motion background menu? I have been trying my best to figure it out but i just don’t know how?
Michael Autery replied 21 years, 4 months ago 4 Members · 4 Replies -
David Garrett
May 3, 2005 at 1:58 pmhere’s one way by using After Effects.. this is for a “first play” motion menu, but no doubt you will be able to modify parts of the process. https://www.wrigleyvideo.com/forum/index.php?showtopic=13770
I have done a tutorial on how to create a basic motion menu menu using photoshop and encore. but i am unable to upload to my web site at the momment, once all is sorted out i will post the link for u.
David Garrett
May 3, 2005 at 5:23 pmhttps://www.sitesled.com/members/doogs/basic%20tuts/(basic)%20tut%204%20motion%20menu%20basics.exe
This is a basic tutorial (and i do mean Basic) but this should give you some more ideas on how to create your own..
Martin Tiller
May 4, 2005 at 3:06 amIf you don’t have after effects it’s fairly simple to do it in PP (or any other NLE).
Import what you want as your back ground from PP as an .avi and import it as an asset, but not as a menu at this point.
In the editing of the menu attach the avi into the properties pallette as the background.
(I’m not 100% it’s in the properties pallette’s, as I don’t have Encore open at the moment, but it is obviously under the edit menu workspace…)From there you need to go under file and click “render motion menu”. And then when you check the preview you will see the motion of the video.
The render part was the step I was missing the first time I tried one.
If you want video thumbnails that’s a different process, but you still to click render video under file.
Let me know if this helps.
Martin
Michael Autery
May 6, 2005 at 5:49 amHi,
Stop by my site and download a couple hundred
Regards,
Michael Autery
DVD-Makers.com
200 Encore Motion DVD Menus &
260 DVD Motion Menu Backgrounds
