Activity Forums Maxon Cinema 4D How do i make a circular brushed metal texture
  • How do i make a circular brushed metal texture
    Posted by Chris Craig on June 7, 2016 at 1:10 am
    Hi guys
    I am trying to create an image in C4D, which has the below-brushed metal texture, and i cant figure out how to create the texture. I have a circular disc, which i have cut out (de-bossed) from within it…my logo.
    Can anyone advise what i need to do to create the texture?
    Thanks a lot
    Chris Craig replied 10 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 7, 2016 at 3:31 am
    There are two ways you can do it:
    1. Use the reflection channel with a Type: Anisotropic layer. There are a lot of settings to play with here but it can produce a very nice result with some trial and error;
    2. Use the Effects>Lumas shader in a material’s luminance channel with the Anistoropic option turned on. Again, there are a number of settings and it takes some experimentation. This is less realistic than the reflectance option but it renders faster.
    Examples: 10166_circularaniso.c4d.zip
  • Chris Craig
    June 7, 2016 at 11:23 pm
    Thank you Adam. Its a good starting point for me to play with. Thanks a lot
