Activity Forums Adobe After Effects How do I loop the puppet tool
  • How do I loop the puppet tool
    Posted by Paul Weiss on October 5, 2008 at 10:57 pm
    Hello. I want to create a walk cycle with the puppet tool but I don’t want to animate through the whole composition (it is a walk CYCLE after all). How do I loop an animation made with the puppet tool? Thanks in advance.
    Darby Edelen replied 17 years, 11 months ago 2 Members · 1 Reply
  • Darby Edelen
    October 6, 2008 at 4:06 am
    You’ll need to decide on a duration for the cycle (e.g. 5 seconds) then animate your puppet pins to arrive at the same location at 5 seconds as they were at 0 seconds.
    Then you can either pre-compose this animation and apply time remapping with a loopOut() expression to the pre-comp, or you can apply loopOut() to each of the keyframed puppet pins.
    Darby Edelen
